Updating the rear spring pack
Old Jan 24, 2003 | 02:18 AM
GeneStoner's Avatar
GeneStoner
What needs to be done to my '74 F100 (9" rear end) to upgrade the rear spring pack to, say, F350 standards?
It already has air shocks and an anti sway bar on the back...
TIA
GS
Old Jan 24, 2003 | 03:42 AM
Torque1st's Avatar
Torque1st
Posting Legend
Gene, incresing the spring stiffness will NOT increase your load capacity.
Check out some of the info on loading in this forum like:
https://www.ford-trucks.com/forums/s...threadid=93527
There are many others also.
Lucky dog, -I see you live in Seattle!
Old Jan 24, 2003 | 06:49 AM
macguyver's Avatar
macguyver
Gene,
Think about it. Do you really want to put as much weight as a 1 ton can carry on those little axle shafts and single bearing? Axles can and do break.
Don't do it!
Just my $.02
Greg
Old Jan 24, 2003 | 10:19 AM
GeneStoner's Avatar
GeneStoner
Well, I also plan on updating the entire rear end at the same time I upgrade the springs...
So, what needs to be done?
Old Jan 24, 2003 | 10:37 AM
stargazer's Avatar
stargazer
gene,
are your exsisting springs 3" wide or 2.5" wide?
if they are 3" you can put any 3/4 ton dana 60 or 70 rear axle from a 73-79 and some others all the way to 96 will fit under your truck along with the springs.
if they are the 2.5" varity I am not sure if the wider springs will fit the spring mounting brackets.
also the driveshaft will have to be shortend a couple inches because the dana axle reaches farther foward than the 9" ford.
Old Jan 24, 2003 | 12:33 PM
GeneStoner's Avatar
GeneStoner
of course, they are the wimpy 2.5" wide springs...
Old Jan 24, 2003 | 02:39 PM
460429_freak's Avatar
460429_freak
Gene what are you planning on doing with this truck? just wanting to add some springs to haul loads a little better? or as a 1 ton?
The first to upgrade the spring pack you will need
1) torch (opt.)
2) new springs
3) new I bolts
4) new U bolts
5) floor jack and jack stands
6) nice level concrete floor
more to list but we need to know what you are planning to do with this truck.
If you intend to use it as a 1 ton you might as well junk it now.
the frame is week compared to a f-350 even if you put all the f-350 parts you will bend the frame. I did this to my trusty ol 68 f-100 now its getting a 4x4 f-250 frame (next project)
1/2 tons are intended for driving truck and light loads not exessive loads I have had two 1/2 ton trucks and over worked them both now I buy only 3/4 or 1 ton's
Old Jan 26, 2003 | 03:53 AM
GeneStoner's Avatar
GeneStoner
I plan on doing some light towing and want to upgrade the rear end while I am at it...
If I am going to go through all of the trouble to rebuild the rear end, I may as well upgrade the whole package (springs and axles).
