Vapor lock? PLEASE HELP!!!!
Old Mar 18, 2010 | 02:57 PM
1965f100factory4x4's Avatar
1965f100factory4x4
Exclamation Vapor lock? PLEASE HELP!!!!
Can you please explain the symptoms are and what it is and how I can stop it. The motor is a 390 CID in a 63 merc, 18k miles since new if that makes a difference. Please help!
Old Mar 18, 2010 | 04:09 PM
jowilker's Avatar
jowilker
Not hot enough for vapor lock, nor have I heard any first hand experience with it in years.
Why don't you describe the symptoms of your issue (in detail please) and lets go from there.
John
Old Mar 18, 2010 | 07:33 PM
1965f100factory4x4
We haven't started the motor in about 5 years but it does rub, I really don't recall what it does but I'm pretty sure it's vapor lock.
Old Mar 18, 2010 | 09:19 PM
Bear 45/70's Avatar
Bear 45/70
Vapor lock is when a part of the fuel system gets so hot that the gas boils, creating an air pocket usually at of near the fuel pump. Then there is no fuel flow. You can't vapor lock a cold engine. Even a warm engine is unlikely to vapor lock until you shut it off and let the temp rise for 15 to 30 minutes, then the engine starts and runs on the gas in the carb (or not if the carb fuel percolates) then dies because there is no additional fuel. There is another thing that happens, but it is also with a hot engine and it is shut off. The fuel in the carb boils and then there is a crank no start. It is called percolation as previously mentioned.
You are assuming you have something you may not have. Describe what is happening rather than assume something you know nothing about by your own admission.
Old Mar 19, 2010 | 12:28 AM
1965f100factory4x4
Well we thinks that cause back when we drove the car we replaced the whole complete fule dilervry system, rebuilt the carB but I can't remember what types of sounds there was or what it does, thanks a bundle for telling me that wonderful info and it will be put to use.
Kamden
Apr 28, 2011 09:11 AM
Katmandu
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 31, 2005 02:52 AM
KPO
3.8 & 4.2L V6
Dec 23, 2002 09:16 PM
TallPaul
Feb 11, 2002 03:59 AM
79supercab4x4
Feb 28, 2001 08:43 AM
