Changing fuel sending unit
Old Mar 17, 2010 | 11:49 PM
Jordanz_03's Avatar
Jordanz_03
Well im changin my fuel tank sending unit this weekend...Any tips or tricks that i should know bout before i dive right in? Would it be easier to just drop the tank or take the bed off?
Edit-Its an 86 150 with an efi 302 and a 4 speed...dont know if yall need to know that or not
Old Mar 18, 2010 | 12:03 AM
fepowerguy8's Avatar
fepowerguy8
When I changed mine I dropped the tank. Careful you don't wreck the electric plug. I found it easiest to remove the filler hose and the plug and hoses before removing the straps. The front strap bolts are kinda hard to remove.
Old Mar 18, 2010 | 12:05 AM
Jordanz_03's Avatar
Jordanz_03
Ya i know straps aint cheap so im gonna be very careful im just trying to figure out the easiest and fastest way to do this..i also found out that my tank may be leaking. Theres what looks like fluid leaking out and its eating away the paint or whatever is on the outside of the tank and i can smell raw gas like no other.
Old Mar 18, 2010 | 12:07 AM
Rogue_Wulff's Avatar
Rogue_Wulff
The bed removal pretty much requires either an extra body or 2, or another method of lifting it.
Dropping the tank can be done by one person, assuming it isn't full of fuel. Hint, fuel weighs in around 7-8LBS/gal.
Old Mar 18, 2010 | 12:10 AM
Jordanz_03's Avatar
Jordanz_03
im gonna have my buddy over helping me out..but like i said if its easier to drop the tank ill do it that way, if its easier to lift the bed il do it that way
Old Mar 18, 2010 | 12:13 AM
Rogue_Wulff
Well, if the tank is also leaking, it will most likely have to come out anyways......
Old Mar 18, 2010 | 12:19 AM
Jordanz_03's Avatar
Jordanz_03
im not 100% sure if it is or not
Old Mar 18, 2010 | 12:29 AM
Rogue_Wulff
Truely, it's pretty much a wash on which is easier. Most people choose dropping the tank so it can be inspected, cleaned, and repaired as needed. Having 1/2" of grime in bottom of a tank isn't a good thing, and getting it cleaned out pretty much requires having it removed from the vehicle.
This method also allows checking/replacing the padding that's between the the mounts and tank.
Old Mar 18, 2010 | 12:47 AM
Jordanz_03's Avatar
Jordanz_03
Ok, now is there a way to clean out the inside of it? and once its empty and clean ill be able to tell for sure if it is in fact leaking
Old Mar 18, 2010 | 01:51 AM
kermmydog's Avatar
kermmydog
The last time I checked you have to buy the pump/sending unit as a package. You use to not be able to buy them separately.
Craig
