Need e-brake pic (underside)
Old Mar 17, 2010 | 09:55 PM
Stephen67's Avatar
Stephen67
Well after hanging around under my truck today I noticed that my e-brake isn't hooked up, I need a picture of what it looks like when it's right.
I should note it's an '56 F-600, the e-brake tightens a collar around the driveshaft, I had thought most normal e-brakes went to the brakes.
I have 3 pieces, two that seem to go on either side that connect to the collar part above the spring, and one that is connected to the handle. Seems I'm missing a bolt or something, looks like maybe the curve on the bolt head would go through it, but how the poop it came off it in the first place is beyond me, I'd just like to see one how it's suppose to be attached before I try to get that back on assuming I'm right... lol doesn't look fun.
I can get a picture if need be, probably be easier than saying "this and that and one of those"...
Thanks
Old Mar 18, 2010 | 12:09 PM
3414's Avatar
3414
Back then anything much above 3/4 ton had a transmission mounted parking brake.
From what you describe, you have an external band type. There were 2 different types, one with a "hub" on the output of the transmission and a band that squeezed around it (external band), and one with a brake drum on the output of the transmission and 2 internal shoes that would contact the inside of the drum (internal expanding).
The shop manuals usually show the linkage pretty well, and detail how to adjust. A Motors or Chilton manual covering medium trucks would also have this info. There is usually an adjusting ros and a clevis in the linkage. I do not have a picture of either, but could take one of the internal expanding type this weekend if it would help.
Old Mar 18, 2010 | 12:35 PM
Stephen67's Avatar
Stephen67
I think it's the external band, I'd go and take a picture but today instead of being 70 degrees like it was yesterday it's litterally a blizzard... good old Wyoming.
Thanks for the help.
