Is this normal for a glow plug?
Old Mar 17, 2010 | 09:40 PM
idahodisco's Avatar
idahodisco
I sprayed my truck down and noticed some air bubbles around my # 4 glow plug when it was running! I dont think its loose that I could tell is this normal?
Old Mar 17, 2010 | 11:34 PM
starmilt's Avatar
starmilt
No.........
Old Mar 18, 2010 | 12:09 AM
idahodisco's Avatar
idahodisco
How tight do they need to be? Should I remove it and replace the glow plug?
Old Mar 18, 2010 | 12:24 AM
LCAM-01XA's Avatar
LCAM-01XA
try tightening it down some more, it's a cone seat at the bottom so it should seal eventually. While you're at it, spray some water around your injectors as well, you may find even more compression leaks.
Old Mar 18, 2010 | 12:29 AM
idahodisco's Avatar
idahodisco
On a scale of 1 to 10 how much back should I put in to it?? I dont want to break the little guy!
Old Mar 18, 2010 | 12:46 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
water! uh oh.
Old Mar 18, 2010 | 12:54 AM
starmilt's Avatar
starmilt
Why uh oh.
Old Mar 18, 2010 | 12:57 AM
idahodisco's Avatar
idahodisco
Ya why uh ho??
Old Mar 18, 2010 | 01:21 AM
Sycostang67's Avatar
Sycostang67
The motor was cold when you sprayed it right?
I actually have a compression leak around one of my injectors. I'm ordering new injectors this week though.
Old Mar 18, 2010 | 01:37 AM
idahodisco's Avatar
idahodisco
Yes the engine was cold! So I have to check it worm is what your saying?
Old Mar 18, 2010 | 01:49 AM
Sycostang67
I just wanted to make sure you weren't spraying a hot engine with cold water, heard too many horror stories about that.
With water, I have to wonder if it was boiling and not air bubbling out. I found my leak after I changed injector o-rings and had some fuel still in the groove around the injector.
Old Mar 18, 2010 | 01:58 AM
idahodisco's Avatar
idahodisco
It was cold and it was around the glow plug it was air bubbling out I am shure!
Old Mar 18, 2010 | 11:23 AM
Sycostang67
I would just try tightening it a bit more. If that doesn't work, back it out a little bit and put some anit-sieze on the top of the threads and tighten it back down. Maybe that will help seal it.
Old Mar 18, 2010 | 01:05 PM
LCAM-01XA's Avatar
LCAM-01XA
Yes, the water test should only be performed on cold engine, you'd think that's a common sense thing but I guess there are always exceptions to the rule. Do what Sycostang said tho, back it out a bit and then tighten it down, you'll ave a good feel of howtight she is then. And anti-seize is always a good idea.
