Sponsored by: Real Truck
Installed front shackles.... UGH!!!
Old Mar 18, 2010 | 02:53 PM
350on44s's Avatar
350on44s
Originally Posted by bbender85
i wonder how many pages this one will go, lol.
i wouldn't say shackles are a bad idea in every application; i've been running 1.5" lift shackles with 4" lift springs for over 3 years now, problem free.
Do you have the front drop brackets as well? Or just the rear shackle? And how long is the shackle? (center of bolt to center of bolt)
Old Mar 19, 2010 | 03:29 PM
10tim86's Avatar
10tim86
Originally Posted by 350on44s
The blocks did not cause the collision though, right?
That's correct, they did not cause the collision. However, they caused much greater damage to his truck. Should have been body damage and maybe front frame damage, NOT axle, driveshaft, transfer case, and frame damage.
Old Mar 19, 2010 | 06:31 PM
bsfarmer's Avatar
bsfarmer
NEVER use a front lift block. There is alot more lateral force being put on that axle than the rear, they do spit themselves out and that is why everyone says DONT DO IT! My buddy's father was nearly killed when he spit out a front lift block on the highway. I'd have to do my research but I also believe they are illegal pretty much everywhere. If its just a trail rig who cares, but when you drive it on the street you are not only risking your life but everyone else's out there.
