429 CJ\SCJ heads???
Old Jan 23, 2003 | 09:13 PM
5x5F150's Avatar
5x5F150
429 CJ\SCJ heads???
My father had a 429 in an old pickup (not orig. engine). It was some old 3/4 ton, 4spd, but the sob would lite up the tires while rolling down the highway at 60mph with 1000l of fuel in the box, reaching a top speed of 130mph. The engine had a terrible ending though, it carefully placed half a rod all over and through the oil pan, ruining the crank and the block. The heads were saved as well the cam(for specs only) but I can't find any web pages with Ford Engines casting numbers. Is there any easy way to determine the reason fo the power, is it the heads or just a freak engine, or is that the kind of hp one can expect from a 429?
Eli
Old Jan 23, 2003 | 09:55 PM
Mil1ion's Avatar
Mil1ion
429 CJ\SCJ heads???
Just browse through other 429 related threads here and you will know all about them.
Compression ratio 10.5:1,11:1 was a big bonus
Check out this link!
http://www.oemfordparts.com//faq/bigblockv8.htm
Old Jan 23, 2003 | 09:58 PM
Ford79's Avatar
Ford79
429 CJ\SCJ heads???
  • CJ/SCJ heads have casting # D0OE-R
  • Police Interceptor heads have casting # D2OE-AB
  • High compression (small chamber)heads have casting # C8VE,C9VE,D0VE
  • Low compression (large chamber)heads are #D2VE,D3VE and so on
