brake pedal help???
Old Mar 16, 2010 | 04:33 PM
big 69 f-250's Avatar
big 69 f-250
brake pedal help???
hey yall i have a 69 f-250 does anyone know if their is a way to adjust the height of the brake pedal i have to lift my leg really high to hit the brakes i just wondered if there was an adjustment thanks
Old Mar 16, 2010 | 04:43 PM
jowilker's Avatar
jowilker
Sounds like you have power brakes, those are designed to roll your foot off the gas pedal and onto the brake pedal without lifting.
You may be able to adjust the rod that goes into the booster out a little.
John
Old Mar 16, 2010 | 04:48 PM
big 69 f-250
thanks i will give that a try yea i should of said it has drums all they way around and power brakes thanks again
Old Mar 16, 2010 | 05:32 PM
big 69 f-250
ok i looked at it it looks like it needs to go in and it has a jam nut on it am i correct in assuming it adjusts like a tie rod end?
Old Mar 17, 2010 | 12:52 AM
bmuhlbach's Avatar
bmuhlbach
I just measured a 72 with power brakes and the pad of pedel was 9 inches off of floor to the pedel.On my 68 with a 77 power brake set up the pedel is 6 inches off floor to pad of pedel
Old Mar 18, 2010 | 02:32 AM
grockin2004's Avatar
grockin2004
If you adjust that booster rod, make double sure that the drum brake shoes on all 4 wheels are self adjusting properly and that you don't run out of pedal before the shoes can apply enough pressure to the drums. A high pedal my be intentional due to 4 wheel drums. Disk brakes ride closer to the rotor and don't need as much pedal movement to fully apply.
Old Mar 18, 2010 | 04:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FYI:
The brake pedal is the same: 1968/72 F100/350 with or w/o power brakes (C8TZ2455E).
The brake pedal used on 1967 F100/350's is 1967 only (C7TZ2455D).
