6.0L engine stalling
Old Mar 16, 2010 | 09:41 AM
LostMedic's Avatar
LostMedic
We have one particular unit (ambulance) '06 E350, which got a full new engine last year at 60K, that will suddenly stall, even when running. It will re-start like nothing happened. There is no DTC's and it runs fine otherwise. We replaced the key cylinder and switch as we noticed some burn marks on the switch but it did not change anything. The hotline is telling us to check STC fitting, ICP and IPR sensors, otherwise install an new engine harness. Any other ideas ? Thanks !
Old Mar 16, 2010 | 11:04 AM
Maxium4x4's Avatar
Maxium4x4
This would be one of those "You have to be here" situations. It does not sound mechanically related or sensor related such as the ICP from your post. You would have to monitor all inputs and when the engine up and dies, do not move the ignition key, check for voltage. Problem is an IV bag is not a good tool to check for engine related situations since you are not a mechanic and your mechanic is not a paramedic who needs his unit in dire situations. The new engine install has plenty of areas to pinch wiring causing problems in the future.
Old Mar 16, 2010 | 07:25 PM
cheezit's Avatar
cheezit
do any of the dash lights come on like the pcm has reset?
pcm diode... try wiggling that see that a few times. also check pins at ficm relay for correct fit. that bit once too. both were econo wambulances
Old Mar 17, 2010 | 08:09 AM
LostMedic's Avatar
LostMedic
Thanks to both of you. I'll have those connectors checked out. I'm trying to take the simple avenues here before changing a full harness
Old Apr 22, 2010 | 09:23 AM
LostMedic's Avatar
LostMedic
Just a heads-up on this specific issue. We checked the connectors and ended up changing the ICP sensor. We've not heard from that problem since.
Old Apr 22, 2010 | 09:30 AM
69cj's Avatar
69cj
Good luck. Over a month and no occurance. Hopefully you got it before it's my turn for a ride in your fine vehicle.
seagull369
1997 - 2003 F150
Feb 17, 2016 11:26 PM
majkthreads
Jun 15, 2013 04:41 PM
screwy
General Automotive Discussion
13
Oct 16, 2006 07:22 PM
Dukster
May 18, 2006 12:52 PM
jcmiller
Mar 8, 2005 12:39 AM
