Warner 4406-21, Rebuild or Replace
I finally locked down the transfer case as the problem this weekend. While driving down the freeway, I had this odd inclination to grab the transfer case shift lever and pull it to the left slightly. As soon as I moved the shift lever to the left, the noise decreased substantially. It did not diminish completely, but almost.
Once I got home I put the transfer case into Neutral and then put the transmission into overdrive to simulate driving down the highway. I got under the <nobr style="color: darkgreen; font-weight: normal; font-size: 100%; font-family: verdana,geneva,lucida,'lucida grande',arial,helvetica,sans-serif;" id="itxt_nobr_3_0">truck
</nobr> and pin pointed the noise to the transfer case. I believe the noise is traveling through the shift lever into the cab.I've spoken with a Jeep guy at work, and he explained that it might be the chain in my transfer case slapping on the case. Does this sound right? It makes since to me. The noise does not occur while the vehicle is in <nobr style="color: darkgreen; font-weight: normal; font-size: 100%; font-family: verdana,geneva,lucida,'lucida grande',arial,helvetica,sans-serif;" id="itxt_nobr_4_0">4x4
</nobr>.What should I do now?
Should I have the transfer case rebuilt? (It has 170,000 miles on it)
Will I be able to muscle it down and back up into place?
I read in another thread that the transfer case needs to be aligned. Is this true?
A re-manufactured transmission is out of the question. I've got one quote for $1200 and I don't have the funds to buy a re-manufactured transfer case.
