TAKING LONGER TO START????
Old Mar 15, 2010 | 09:27 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
SO WHAT THE ANSWER BATTERIES OR SOMETHING ELSE.
Old Mar 15, 2010 | 09:32 PM
fordpride's Avatar
fordpride
i would get your batteries tested and go from there
Old Mar 15, 2010 | 09:34 PM
PAVEMENTMAN
OK. DO YOU THINK IT COULD BE GLOW PLUGS. AND IF ITS THE BATTERIES WHAT IS A GOOD BRAND.
Old Mar 15, 2010 | 09:37 PM
fordpride's Avatar
fordpride
what are the temps. there i use interstate batt.
Old Mar 15, 2010 | 09:41 PM
PAVEMENTMAN
IT HAS BEEN DOING THIS WARM OR COLD FROM 70 IN THE SUMMER TO 15 IN THE WINTER.
Old Mar 15, 2010 | 09:44 PM
fordpride's Avatar
fordpride
do you have any fuel leaks
Old Mar 15, 2010 | 09:46 PM
PAVEMENTMAN
NO. NONE AT ALL.
Old Mar 15, 2010 | 09:47 PM
fordpride's Avatar
fordpride
check batt.
Old Mar 15, 2010 | 09:49 PM
PAVEMENTMAN
OK. THANKS FOR THE INFO I APPRICIATE IT ALOT. THERES ALOT OF GOOD INFO ON HERE.
Old Mar 15, 2010 | 11:26 PM
strokin'_tatsch's Avatar
strokin'_tatsch
yep, if it's doing it at all those temps even when plugged in i would look at the batteries first. the glowplugs aren't your culprit if it does it even when plugged in. makes me think your romping when warm problem may not be IPR o-rings b/c they would take longer to start when warm, not cold though. hmmmmm...
Old Mar 21, 2010 | 08:27 PM
PAVEMENTMAN
WELL I FOUND MY PROBLEM. THE TRUCK SITS ALL WINTER SO I JUST TOOK IT TO THE STATION AND PUT SOME FRESH DIESEL FUEL IN IT AND IT FIRES RIGHT AWAY NOW EVERYTIME.
