rochester help
Old Mar 15, 2010 | 07:08 PM
stormdraconis's Avatar
stormdraconis
rochester help
Need to know how to get a rochester set up to use on a 351 w the reason is that the motorcraft holley 4180 is messed up on the primary fuel bowl so I got to replace with something else would like to get the rochester on it to save some money but if I get no solution then I will have to spend some money on an edelbrock but only if this will not work. It also a mechanical choke if that helps
Old Apr 12, 2010 | 10:44 PM
samtye's Avatar
samtye
will a rochester even fit on a ford? thats ****rolet stuff
Old Apr 18, 2010 | 01:31 AM
wdfp's Avatar
wdfp
The main problem will be if you have an automatic trans, you have to be quite creative to hook up the kickdown linkage.. If its a standard then you can get a manual choke hook up for the qjet, and it should have enough vacuum hook-ups to work for you as long as there are no elctronics involved
Old Apr 19, 2010 | 05:50 PM
LxMan1's Avatar
LxMan1
No kick down lever for a Ford and you will have to use a carb adapter which really hurts flow. I assume we are talking about a Quadrabogg 4bbl?
Old May 7, 2010 | 08:00 PM
7Ford6's Avatar
7Ford6
Here's what I did --- https://www.ford-trucks.com/forums/9...ml#post8841668
