460 trouble!
Old Mar 15, 2010 | 03:06 PM
1979FORD400's Avatar
1979FORD400
460 trouble!
I've got a 1985 F350 that I just put a 460 that I rebuilt in. I have it running but it won't run good. It backfires through the carb. and won't stay at a constant speed it moves from 2000 to 1500 and idles way to high. All the wires are in the right spot and tight and the distributor cap is not cracked or wet. The timing should be close. Any ideas???
Old Mar 15, 2010 | 03:25 PM
bashby's Avatar
bashby
Vaccum leak maybe, I'd get a timing light on it to be 100% sure
Old Mar 15, 2010 | 03:26 PM
fatdan460's Avatar
fatdan460
distributor is probably 180* off
Old Mar 15, 2010 | 05:24 PM
fepowerguy8's Avatar
fepowerguy8
I agree, it sounds like the distributer is 180 degrees out.
Old Mar 15, 2010 | 05:39 PM
Poison Oil Racing's Avatar
Poison Oil Racing
Originally Posted by fepowerguy8
I agree, it sounds like the distributor is 180 degrees out.
I third that
Old Mar 15, 2010 | 06:31 PM
cadunkle's Avatar
cadunkle
Go over your basics. Vacuum leaks, timing, carb, rockers, etc. Backfiring out carb is most likely from wrong firing order (you checked that though), timing, rocker too tight on intake side, bad valve/seat, VERY lean mixture (thoguh usually only under load). Go over the basics again and if no dice do a compression test.
