Sponsored by: Real Truck
Spray on bed liner!
Old Mar 16, 2010 | 03:40 PM
function12's Avatar
function12
Line X on three different trucks. I don't like the looks of Rhino. Looks like melted crayons.
Old Mar 16, 2010 | 11:16 PM
smotrs's Avatar
smotrs
Line-x is a stiffer/harder material and is considerably harder to cut or slice thus resulting in damage. Less likely to be damaged when using truck as a work truck. Repairs take a bit of work to perform but is possible. Because it's a harder material when cured, it also means that there has to be good preparation before applying or it could peel up easily. Important to have a reputable dealer install for best results. Material is applied using a high pressure system.
Rhino is a softer compound and can be gouged and or cut easier. Very easy to damage when using truck as a work truck, especially on hot days. Repairs are easier to make when damage does occur though. Good preparation is still needed for proper installation, but may be more forgiving, still possible that it can lift or peel after it's been applied poorly. A reputable dealer installation will result in great results. Material is applied using a low pressure system.
I had Rhino in my Nissan, went with Line-X in my F250.
Azuretruck
Dec 8, 2016 08:11 AM
F-350&F-250
May 19, 2016 05:27 PM
balderman
39
Sep 22, 2015 03:23 PM
fxhdfd
2009 - 2014 F150
Apr 24, 2014 06:42 PM
Hawkeye1
Florida Chapter
Aug 29, 2004 11:57 AM
