1978 - 1996 Big Bronco
PUZZLING ISSUE WITH NITE BRONCO
Old Jun 22, 2010 | 12:10 PM
  #31
Torky2's Avatar
Torky2
Originally Posted by BULLETPROOF4.9
Ok, It has a new distributor and pickup, it starts when the key is turned, the fuel pump comes on, the coil is good, so it the computer. Voltage to the coil, but no spark. New battery cables. I'm at a loss. Can you say gasoline and a match?
Hold off on the match!!! You're almost there! At least it is "reliably dead". Those are the easiest to troubleshoot... though you may not be feeling that. The WORST are the rarely-occuring intermittent problems that leave ya stranded, but when towed home everything is fine!
You just answered my next question, which was whether you have the TFI module on the side of the distributor, or if you just have a plug hanging out of the distributor and have the ICM on the fender instead. So it's ICM on the fender.
From the 1994 electrical book, here is the circuitry around the ICM and the distributor. I am thinking that 1992 will be the same or similar. Looking at the colors of the wires you have will tell, if they match up to what I posted. If so, you can use it.
Since plug-in replacement of parts hasn't solved the problem, after checking fuses I think its time to check wire continuity, and if voltages are present in Start/Run.
Wire Color Code
GY/O GraY with Orange stripe
PK PinK
Y/BK Yellow with BlacK stripe
R/LG Red with LightGreen stripe
T/Y Tan with Yellow stripe
BK/W BlacK with White stripe
W/PK White with PinK stripe
O/R Orange with Red stripe
The ICM (Ignition Control Module) on the fender has 6 wires. They are color-coded using the first 6 of the colors listed above, and are in order from one side of the connector to the other.
At the ICM connector there is:
GY/O is PIP, runs to the plug on the distributor, also has a splice somewhere along it that it also runs to pin 56 of the PCM (the computer).
PK is SPOUT, runs to the SPOUT connector jumper plug, from there, same PK color code, runs to pin 36 of PCM.
Y/BK is START, runs to pin 4 of PCM. I assume the PCM puts 12volts on this only when key is in START.
R/LG is POWER, with same color code goes a lot of places: to a fuse where it is getting 12volts through the key switch in START and RUN, to the distributor, to the hot side of the coil, radio noise capacitor near coil, and other places too. But these are the ignition-related places it connects.
T/Y is COIL, runs to the other low-voltage side of the coil. Also has a splice somewhere to W/PK wire which runs to dash, probably to pulse the TACH.
BK/W is GROUND, runs to distributor.
At the distributor connector there is:
GY/O PIP, already covered that above.
O/R IGNITION GROUND, runs to pin 16 of PCM. I think that is a signal ground that works with PIP.
R/LG POWER, already covered that above.
Inline connector – there is a Connector C101 that is inline for some of the wires from the ICM to the distributor and coil. It is over near the driver’s fender somewhere by the air box.
Old Aug 30, 2010 | 09:47 PM
  #32
BULLETPROOF4.9's Avatar
BULLETPROOF4.9
Ok, I took care of my problem. I SOLD IT as is. It's now someone elses problem.
Old Aug 31, 2010 | 07:04 AM
  #33
Encho's Avatar
Encho
The Southernmost Mod
Oh well, you still have the Eddie Bauer, i think it would have been better changing that wiring harness to start fresh and checking all the grounds. Still, yours was a great solution, works everytime.
427 fordman
44
Sep 27, 2012 07:01 PM
xplict
15
Nov 3, 2011 09:12 PM
jaceqq
Nite, Nascar & Other Limited Edition Ford Trucks
Jun 4, 2008 08:36 PM
jaceqq
Jan 27, 2008 03:47 PM
nonieanna@ev1.net
Apr 12, 2004 11:43 AM
