fuel injection control module harness and throttle sensor
Old Mar 14, 2010 | 05:13 PM
tcoates's Avatar
tcoates
well i have decided to replace both in my 03, probably should just replace both, but the sensor shuts the truck off when i wiggle the harness and when i am going down the road my truck falls off to an idle, some times just shuts off untill i let off the throttle and push down again or put it in nuetral and restart. since i don`t believe the harness is supposed to shut the truck off when i wiggle it i will start with that. does anyone know what the cross over from ih pat #1843476c92 is . my ford dealer says there is 5 different harness` for the truck and needs the # off the harness and gave him the ih #, said needs ford part #. also does anyone know the part # for the pedal [throttle position sensor] with adjustable pedal? my dealer adds 33% to msrp so if i can get the part numbers i will order from world parts express which gives 35 or 40 percent off ford parts. anyhelp would be appreciated. thanks. tracy
Old Mar 14, 2010 | 05:18 PM
tcoates's Avatar
tcoates
well what i ment to say, the truck shuts off when i wiggle the harness, and i probably should replace the truck. edit button did`t work.
TheBlueMule
Jul 7, 2015 11:16 AM
acf6
Feb 2, 2015 06:50 PM
Tlid1011
Oct 22, 2014 08:49 PM
charles5000
Jan 28, 2014 07:31 AM
79f-250custom
16
Nov 16, 2008 10:01 AM
