Engine Swap!
Old Mar 13, 2010 | 06:42 PM
sogmc's Avatar
sogmc
Engine Swap!
Can I take a 351w from a 1984 F250 and put it in my 1986 F250 that already has a 351w in it, & can I do it without any modz????????
Old Mar 13, 2010 | 06:56 PM
Franklin2's Avatar
Franklin2
It will certainly fit, but there will probably be little things that need to be swapped. If you want to do no head scratching, then you will probably have to strip the 84 down and put the 86 carb, sensors, vacuum lines, etc. on the 84. If the 84 was v-belt and the 86 was serpentine belt, you will need to swap the waterpump and fan from the 86 to the 84 block to keep the serpentine system.
