Drain tranny before pulling engine?
Old Mar 13, 2010 | 10:30 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Do you have to drain a C6 before pulling the engine? Especially if I'm careful about keeping the TC on the pump/shaft. I'd really rather not if it's not a necessity. So much fluid...
Old Mar 13, 2010 | 11:06 AM
82ford302's Avatar
82ford302
no draining is needed if the trans is staying in the vehicle. but it would be wise to install a new front pump seal while you have access to it.
Old Mar 13, 2010 | 11:25 AM
BaronVonAutomatc
Far out, thanks. The tranny has less than 2,000 miles since a rebuild so it ain't coming out and there should be no worries with the seal.
Old Mar 13, 2010 | 12:07 PM
82ford302's Avatar
82ford302
no prob man . you should be ok since it only has 2K miles on it. i always replace the seals wether its rebuilt or not. 5 dollar part and about 5 minutes saves alot of headaches later on lol.
