Rim problem
Old Mar 12, 2010 | 09:40 PM
joe cowan's Avatar
joe cowan
Rim problem
Well Guys: I get one problem fixed and another arises. We installed CPP disc brakes on front of 64 f100 and tried to mount the original rim and tire which are the standard Ford 15" but the rim will not go over the caliper. I think we need 16" rims but what donor truck of any make will have rims that work. Joe
Old Mar 12, 2010 | 10:35 PM
1965f100factory4x4's Avatar
1965f100factory4x4
any ford up until about 96 half tons they all had 5.5inch bolt pattern
1965f100factory4x4
oh and late 60's early 70's half ton international pickups and scouts
Old Mar 12, 2010 | 10:40 PM
Voodoo66's Avatar
Voodoo66
Try later 60's ford rims say 65/66 bc the rims are different on the inside. I had the same problem. Its due to the fact that the 64 rims on the inside are shallow as where the 65/66 have a deeper rim spread.
Old Mar 13, 2010 | 08:10 AM
joe cowan's Avatar
joe cowan
Re-rims
Thanks Guys for your answers to our problem. It is much appreciated. I figured somebody on here would have the answer. Joe
Old Mar 13, 2010 | 09:07 AM
Imspry1964's Avatar
Imspry1964
Joe, you answered my question with your question. I was looking into using the CPP disc brake kit on my 64 f100 and was wondering if the original rims would fit. Now, I know they won't. Thanks.
Old Mar 13, 2010 | 09:36 AM
gritsngumbo's Avatar
gritsngumbo
They WILL fit if you use a spacer (believe it's 3/8" or 1/2"). Use washers to measure how much of a spacer you need.
Old Mar 13, 2010 | 10:22 AM
Imspry1964's Avatar
Imspry1964
Thanks, I'll remember that. I will eventually get custom wheels, but its good to know that if I convert to disc brakes, I can use the original wheels for a while.
Old Mar 14, 2010 | 12:25 PM
popbreed's Avatar
popbreed
I am using my stock 64 wheels on my F100 converted to Discs (Speedway kit) I had a slight interference but ground away slightly on the calipers. I read somewhere it might be necessary. it did not take much to get the clearance. As the pads wear, the caliper moves "out of the wheel" moving away from the interference.
Old Mar 15, 2010 | 12:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Some 1980/83 F100's have 5 lug wheels on a 4.50" bolt circle pattern.
Pickupmanx2
16
Jun 28, 2014 11:52 PM
booberjinx
2004 - 2008 F150
Apr 12, 2007 01:59 PM
joes75
Bronco II
Jun 18, 2002 10:06 AM
