Engine Questions
I got some questions regarding engines in my truck. My 300 is about beat to the last drop I think so this spring I'll be swapping it out. All I keep reading is that the 302 is a pooch? My uncle will be building it. Mildly though, not huge. Will it be that dissappointment? It is my understanding that the winsdor gets horrible gas mileage for its size and I need as much gas as I can get as my 300 is getting 6-8 in 4 wheel drive right now.
Another thing, where would be the best place to get a good block to start? Like what year of truck/car and such. And what is the best auto tranny? Thanks for the help!
One thing for the 300-I6 was torque, and lots of it.
ONE TON
Why not just do a rebuild on the Six? Clifford makes a 4v intake, RV cam (torque), headers are available, just saw new pistons on eBay for $66 (complete set!)....
According to most factory numbers the 300-6 makes better torque than a 302 (in stock form). Torque is what your after in a 4wd!! Your mileage may have more to do with worn out engine than anything else.
You also have to consider your trans/transfer case in all this. Is your truck manual or auto? If it's an original 4wd it's probably got a manual & divorced (separate) transfer case. * Changing out the trans adds a whole new dimension of excitement to all this... literally. Changing trans could mean moving transfer case (case x-member!) and new driveshafts. Changing driveshafts any noticable amount also changes pinion angles. Incorrect pinion angle leads to vibration and short lifespan u-joints. * Keeping trans and changing engine requires the right bell housing. The 302 and 351W share the same bolt pattern as the 300. The 351c/m and the 429/460 share patterns. The FE's 352,390,428 have two different patterns (early 60's vs mid 60's and beyond).
My point in all this..... How deep are planning to go, both into your pockets and your trucks guts?
Jim
Me I liked my six but I love my 302.
The 302 started its life in my 69 Bronco.
Bumped comp ratio to 9.5:1 mild cam with split lift and duration. Kepped the smaller 2 brl heads and manifoild with nothing fancy just a five angle valve job and hi volume oil pump, headers.
In the bronco with 4:10's and 33x10.5x15 I'd get 12 mpg with points and a MSD 6a. Now it's in my 65 with 3:53 and 235x75x15 and i get 17mpg towing my racecar (1500lbs)
Smaller runners in the heads keep flow velocity up so low end is there. The two brl motorcraft/autolite carb works great even on steep inclines.
44Dwarf
Thanks again!
sorry it took so long to respond...my comp is wack.
