charging issue help
Old Mar 11, 2010 | 07:33 PM
slayer3103's Avatar
slayer3103
charging issue help
my 94 f250 is acting up on me my batt light was on and gauge was reading low so i had the alt rebuilt i cleaned all connections and put fresh rebuilt alt in and still same issue batteries are good whats the next step only thing i can find is the single wire on the alt between main battery connection and larger plug is a lil loose
Old Mar 11, 2010 | 08:38 PM
slayer3103's Avatar
slayer3103
bump for help please
Old Mar 11, 2010 | 09:09 PM
RV_Tech's Avatar
RV_Tech
I am unclear as to whether you have taken any voltage readings. Check all connections closely. Lots of alternators get changed when the problem is a ground or cable. What voltage are you getting at the batteries with the engine running?
Steve
