cab lights
Old Mar 11, 2010 | 12:20 PM
starmilt's Avatar
starmilt
cab lights
I have a 76 and a78 that the sun has cooked the cablights,I might could get by with just the lenses, but the bases really need to be replaced too.
Has anyone used any aftermarket ones, preferably led that look correct and fit in the stock position.
Are new oem ones still available if leds have not been reproduced.
Old Mar 11, 2010 | 01:29 PM
Mexican77's Avatar
Mexican77
I got a replacement for my '77 cab light from an Econoline Van in a junkyard they fit I think from models 78-92 and theres a lot of parts from vans that fits our trucks too like the instrument cluster, good luck.
Old Mar 11, 2010 | 01:37 PM
starmilt's Avatar
starmilt
Thanks I would like to find some led replacements, if someone is makeing some good quality ones. But that is definately an option.
berry1234's Avatar
berry1234
You can search the correct bulb number and just add LED and you will come up with a lot of options. I would keep the incandescent IMO. The LED look cool, but are not 'period correct' and fatigue the eyes a bit. LMC has the base and lenses.
Old Mar 11, 2010 | 02:01 PM
Customcab's Avatar
Customcab
I'm always on a budget; I place harbour frieght lights on my recent build; with using a factory correct wirning harness I pulled from a 67 model cab.
I also wired the harness to come on with the parknig light switch is pulled out.
not the answer your looking for but just a thought.
Mitch
Old Mar 12, 2010 | 07:16 AM
Tees77f150's Avatar
Tees77f150
You can get the period correct styles from Napa, I know that is not what you are asking. I would check LMC for what you are looking for.
Old Mar 12, 2010 | 07:31 AM
benmoderow's Avatar
benmoderow
I just got mine from LMC. I ordered the bigger teardrop shaped ones that have the large chrome base. They're a little bigger than I thought they'd be. Anyone use these or have pictures? I'm curious to know how they look on a truck. Lmc also sells the stock reproduction ones, as well as the aftermarket ones
