Spindle removal?
Old Mar 10, 2010 | 06:24 PM
slm135@mac's Avatar
slm135@mac
Spindle removal?
I'm in the process of replacing my ball joints on my 1994 F150 4x4. I'm following the process shown at Bronco Ball Joint Replacement - Trucks 4x4 @ Off-Road.com. I've made it to trying to remove the spindle. I've got all of the nuts off, but the spindle won't budge as shown in Photo #10. I've hit it with a bfh and a block of wood on the spindle and soaked in with PBBlaster. I'll let it soak overnight and see if I can it off tomorrow evening. Will it do any harm if I heat it up with a torch if the overnight soak doesn't work? Any other tricks I can try?
Old Mar 10, 2010 | 07:40 PM
Bob Gervais's Avatar
Bob Gervais
I used an air chisel on mine, to wedge between the spindle and knuckle. They eventually came off.
Old Mar 10, 2010 | 07:54 PM
slm135@mac's Avatar
slm135@mac
Thanks for the suggestion. I'll give that a shot before using a torch!
Old Mar 10, 2010 | 08:02 PM
zxwut?'s Avatar
zxwut?
I used a universal 3 jaw puller.
Old Mar 10, 2010 | 11:33 PM
pghcarp's Avatar
pghcarp
I had the same problem. I used a spindle socket and slide hammer from Auto Zone. You either can purchase or rent it. It came right off.
[IMG][/IMG]
Old Mar 11, 2010 | 06:13 AM
slm135@mac's Avatar
slm135@mac
Thanks! I didn't know that a spindle puller (socket) existed. I get the loaner tool
Old Mar 11, 2010 | 08:55 AM
hav24wheel's Avatar
hav24wheel
BFH, and a couple big chisels. That's all I ever do. Seems to work great. Pound them between the spindle and knuckle 180* from eachother.
Old Mar 12, 2010 | 01:01 PM
slm135@mac's Avatar
slm135@mac
I used the spindle remover with slide hammer and got it off in a few minutes. I don't think I would have got it off any other way. Once it began to move it still took some effort with the slide hammer. Then I had to use a cutting torch to get the nut off the lower ball joint. Guess that's one of the many benefits of living where they salt the roads!!
