lightning heads
Old Jan 22, 2003 | 08:24 PM
kevman's Avatar
kevman
lightning heads
what size valves are in a set of 86 351w lightning heads?
are these considerd good heads or just average?
Old Jan 22, 2003 | 10:34 PM
fastf150's Avatar
fastf150
lightning heads
I am not sure if ford made an 86 lightning? do you mean 96? Any-ways, it the truck was supercharged and your engine will not be, then i would pass on the heads. Generally speaking, forced induction heads from the factory have smaller valves than naturally aspirated ones. This is because the force of air/fuel coming in is so violent that larger valce will shroud the intake and cause excess turbulance in the comb. chamber. I know the 4.3L GMC typhoons had smaller valves than a regular 4.3, and the same went for the Buick Grand National which was on a 3.8L. Don't be jaded just because they are lightning heads. Spend your money on a set of good aftermarket heads that you are sure of. Unless they're free, then by all means, bolt them on!
Old Jan 23, 2003 | 02:02 AM
ecarter50's Avatar
ecarter50
lightning heads
There was no 96 Lightning only 93-95 and 99+. The 93-95 have GT40 heads and are better than regular 302/351. 93-95 Lightnings are not supercharged.
