Proportioning valve ?
Old Mar 10, 2010 | 10:32 AM
19804x4's Avatar
19804x4
I have a leaking proportioning valve.... and can't find one for a 1980 f150.. the ? is can i use one from another year (92).?
thanks for ur help..
Old Mar 10, 2010 | 10:48 AM
fepowerguy8's Avatar
fepowerguy8
I looked online and only found them at junkyard sites., I wonder if a mustang one would work? those are easy to find, and some are adjustable
Old Mar 10, 2010 | 11:00 AM
19804x4's Avatar
19804x4
do u know which years have adjustable ones?
and have u heard of this swap working ?
Old Mar 10, 2010 | 11:38 AM
fepowerguy8
Every year of mustang has available adjustable proportioning valves. Not sure if it would work on the trucks or not, not sure if the trucks use a bigger one or what. I would assume as long as it is the same size fittings it should work.
Old Mar 10, 2010 | 10:25 PM
Franklin2's Avatar
Franklin2
The proportioning valve is calibrated to the weight and style vehicle. If you are going to do any swapping, try to stick with a truck proportioning valve.
Old Mar 11, 2010 | 03:11 PM
19804x4's Avatar
19804x4
Ok .. so with that said would u think that one from an 84 on up would work ? Those years are every where
Old Mar 11, 2010 | 03:27 PM
bashby's Avatar
bashby
It should, even if you have to change the fittings on the end of your lines. It might not work properly but the brake bias should be close enough. I have mine bypassed (rear brakes werent working)
