94 F-150 Door alignment
Old Jan 22, 2003 | 07:45 PM
bosshoss's Avatar
bosshoss
Hey anyone. I had to just replace the door hinges on 94 F150 P/U. Super cab. I marked the originals so i would be close. I am still way off on the adjustments. any tips to make this job a little less a pain. Body work is out of my field. Thanks.
Old Jan 26, 2003 | 09:44 PM
Mike W's Avatar
Mike W
Aligning doors is right up there near the top of things I hate to do. On heavy doors I use a rooling jack, actually my transmission jack, to support the door so it won't drop when the bolts are somewhat loose. Take your time and don't let the door scrape the paint on the fender. Make a slight adjustment and check the fit.
Old Jan 27, 2003 | 08:44 PM
bosshoss's Avatar
bosshoss
Hey Mike, Thanks for the reply. I had to take the finders lose, and line up the doors for the best fit, then align the fenders. Lot of work, but i guess the truck had been hit before, and with bad hinges replaced, it was the only way. Thanks.
Chumpy
New Member Introductions
Nov 19, 2014 09:52 AM
jeffs94F150
Jan 12, 2011 08:45 PM
HTRVIL
Feb 16, 2005 05:24 PM
94I-6
Oct 9, 2003 10:42 AM
