new Chevy Dmax numbers
The new Powerstroke is a clean sheet, new this year. I'll bet it has lots of potential for more power from the factory. Who knows maybe Ford will get pissed off about this bull**** and turn up the juice a smidge to put Gubment' Motors back in their place as the lowest common denominator among car companies.
Time will tell, but going in with a new motor, almost by definition, means the Ford is the LEAST tested of the available drivetrains. And "never tested" by the market should be enough to make smart buyers pause. There is a reason why the commercial upfitters around here are going to Dodge Cummins for now.
This might be a good time to cut back on the Cool Aid.
-mike
Good point. I stand corrected.
Still, I would prefer to see a product cycle where the engine was subject to real world (i.e., not "simulated") testing beyond the product lifespan. For example: While it is swell some Ford employee pulls 10K with a new truck on an Arizona freeway while another drives one around in circles in some dusty proving ground, neither gives us a real world testing. What happens with a couple months of crop chaff and field dust build up, the truck is over loaded (19,000lbs of hay is pretty common) and subject to punishing conditions? Remember, the 03 6.0 was subject to testing but it was not until consumers got ahold of the motor that issues really came out. And the 6.4 air intake and dry snow?
When I observe the Ford communications surrounding the new motor, I see a lot of marketing hype surrounding branding and "tough" - but I do not see a lot of evidence of the product having had time to develop under real world conditions. And again, due to the Ford-related (rather than just Navistar-related) issues with both the 6.0 and 6.4, I am not confident in Ford's ability to deliver a throughly vetted product.
We all know the weakness of the Fiat-Dodge product. But we also know the Cummins motor will generally turn 300k before requiring a re-build.
I think the Ford numbers are impressive. I also think that it is a very difficult task to deliver a clean slate motor producing these numbers while subject to the conditions the buyers will deliver. As a result, I think the cost risk to early customers may be higher than purchasing a product that has had real world development time.
Ford needs this motor to be solid from the get-go because the market is more competitive than ever before.
-mike
The only reason the Duramax makes more power is that extra 200 RPM's. 397hp @ 3000 RPM's equals 695lb-ft of torque, the Duramax isn't breathing as well up top. Looks like GM padded the horsepower numbers by spinning their motor a bit faster. The Duramax on average is losing 1lb-ft of torque for every 20 RPM's the engine accelerates.
Compare this to the Powerstroke putting down 390hp @ 2800 RPM's which equals 731lb-ft of torque at that engine speed. So the Powerstroke gives basically peak torque from 1600 RPM's to 2800 RPM's. All Ford would really need to do is play with the boost map a smidge to maintain boost for another 200 RPM's and they would make over 400hp at 3000 RPM's. For example if we extrapolate the torque loss over RPM increase of the Powerstroke we find that on average it loses 1lb-ft for each increase in engine speed of 300 RPM's. So if Ford remapped the boost to maintain pressure up to 3000 RPM's we would still be playing with around 730lb-ft, and that means an output of 417hp gentlemen. The new Powerstroke is going to behave much like the other reverse flow head in valley turbocharger equipped V8's on the market, like the BMW 4.4L twin turbo V8. Makes a nice strong peak torque number and just holds it for a couple of thousand RPM's, super flexible engine.
What we have here are two different styles of power delivery the GM peaks higher but starts to lose power compared to the Ford later in the operating range, only posting a marginally higher peak horsepower output due to spinning the engine faster. Ford seemed to take a different approach looking for a really flat torque curve for extremely linear power delivery, and they got it. Right around 2100-2200 RPM's on up to 2800 RPM's the Ford will likely be the more responsive and powerful engine. You know, the engine speed you'll be seeing every time you pull out to pass, or downshift to climb a hill.
To put things in perspective at each motors peak torque the Ford makes 224hp @ 1600 RPM's, and the Chevy makes 233hp @ 1600 RPM's. Big deal.
Note to Ford, increase boost pressure by 1.5-2.5 PSI, and extend the boost map an additional 200 RPM's.
Nice post. Good points.
-mike
-mike
I could not agree more and you make some great points.....
<!-- / message --><!-- sig -->__________________
02 F350 Lariat PSD CC 4X4 DRW Built Ford & BTS Tough 825,659 miles, "HIS TRUCK"...My truck is in the sig below,just turned over 80,000 mile's.
Another thing I'm curious about is how the Duramax can add a ninth injector for the exhaust and claim an 11% increase in fuel mileage? Not looking at any other factors except for the added injector would make me believe it would get 11% worse fuel mileage? I wonder how they did that?
Either way, I'm becoming more and more impressed with this New Powerstroke engine. If it really does get the fuel mileage I've seen posted, then I might be in line for one in its second year of production.
Less chance for that fuel to wash down the cylinder walls and dilute the engine oil.
Better fuel economy is better timing and less EGR by using the DEF, diesel exhaust fluid....... with or w/o 9th injector.
I have had fuel dillution in my oil; so I would have rather have seen Ford add the ninth injector. If they had I would be buying soon; since they didn't; I'll wait to hear the reports of early buyers that do oil analysis.
Mine didn't show issues with early oil changes; so I'm going to wait a while for some history......
Bob
