Sponsored by: Real Truck
2010, 2011, or used?
Old Mar 9, 2010 | 07:02 PM
995.4SD's Avatar
995.4SD
Here is the delimma my Dad is in. He has an 05 F-350 6.0 lariat. He just got rear ended at a stop light a few weeks ago by a mac truck doing 40 mph. He is fine, but the same cannot be said for the truck. Today the adjuster told him it was totaled. Now he lives in a 5th wheel, and travels often, so a truck is a necessity. He is trying to decide between buying a 2010, waiting for a 2011 for the new 6.7, or buying a pre 08 model.
What is your guys' opinion on this one? Did they get all the corks worked out of the 6.4? Would it be a reliable stout engine? Or would he be better off waiting and taking his chances with the new 6.7? I think he prefers new over used, but he isn't totally against the idea.
I am bias towards the new 6.7 just because from what i've read it sounds pretty intense, and I don't think Ford wants to keep changing motors and I have a feeling this one will stick...I could be wayyyy off.
Shout out your opinions!
Old Mar 9, 2010 | 07:25 PM
Fordfanatic4life's Avatar
Fordfanatic4life
oh man, hes soooo close to the 2011's, i'd def steer him towards waiting for the new truck..
its got so many new features, i cant see how you could not want one if your new truck shopping.
Old Mar 9, 2010 | 08:56 PM
Bryan966's Avatar
Bryan966
My 2 cEnTs
2011 Bigger and Badder than ever. Improvements galore! Yeah let's have a 2011 party........Oh ya.......Uncle EPA came and said he needs to make some of his own mandated improvements under the hood!
I'd pass on the 2011 if going Diesel! I love new trucks and toys. I have an 09' loaded with every available......but
..........the problem is harsher EPA requirments! The 6.7 looks promising but it is a new block. An all new block. Not to mention wrapped into that block is Uncle EPA's new standards including a Urea injection system. Love the newer trucks but I hate the EPA standards.
Maybe if technology could keep up with Washington's mandates we would have a better diesel truck. We have better trucks......stronger......bigger....better........ including transmissions........but engines and exhausts......well they are "cleaner".........and......ummmmmmm...........
I am glad to see a six speed. It's about time Ford found the extra gear!
Old Mar 9, 2010 | 11:23 PM
995.4SD's Avatar
995.4SD
Ya, I really want him to wait for the 2011. He seems like he wants to just go for a 2010, are there any problem with the 6.4 still?
Old Mar 9, 2010 | 11:28 PM
jac08f250's Avatar
jac08f250
I think they have worked out all of the problems with the 6.4. The only real problem with the 6.4 is the mpg.
Old Mar 10, 2010 | 01:23 AM
redford's Avatar
redford
FTE Leadership Emeritus
The 6.4L MPG problem can be fixed with a DPF delete. Otherwise it is a good engine. When combined with either transmission option you have a very capable and reliable towing platform.
2011? We're seeing impressive numbers, both in power and mileage. Time will tell if the engines and transmission are reliable. That is the big gamble.
Old Mar 10, 2010 | 01:31 AM
DuallyMike's Avatar
DuallyMike
Don't know if it's a consideration for him, but I would think you're going to be getting rebates on the 2010's. Not so the new model, at least not when they are first introduced.
Old Mar 10, 2010 | 09:57 AM
brian42's Avatar
brian42
Veteran: Navy
I would vote for the 2011 if for no other reason that the 6.7L is designed to perform most major maintenance without removing the cab!
Old Mar 10, 2010 | 02:20 PM
mwsF250's Avatar
mwsF250
Another option: Get a used but very well cared for 7.3 (lots out there if you are willing to hunt) and drive it for a couple years.
Conservatively invest the money saved over buying new (and there will be a LOT!) and wait for the verdict on the 6.7. If it turns out to be a winner, sell the 7.3 and buy a 6.7.
The depreciation on the 7.3 will almost certainly be less than the return on the investment! And if he then buys a year or two old 6.7, the net savings will be huge.
Much less risk, and a little less (or maybe a lot less) cost.
Old Mar 10, 2010 | 02:25 PM
mwsF250's Avatar
mwsF250
One other option (if he's not obsessed with the diesel thing) is to get a used V-10. There are indicators that the value on these may actually increase over the next few years. If the 6.7 turns out to be not so good, maybe quite a bit.
Old Mar 10, 2010 | 02:46 PM
scraprat's Avatar
scraprat
Top Answer: 5
That would be tough to decide on and there will probably be a lot of personal opinions, that being said...I personally would rule the 7.3 out only because their getting long in the tooth(7+ years) not so much the engine everything around the engine.
A few schools of thought ...
1- Ford seems to have put their reputation on line with the new diesel, roll the dice be a guinea pig and hope only the small job 1 growing pains are there.
2- Buy a used 6.4 use the experience of previous owners, mod it and throw the warranty out the window. Plus you get the better Trans, brakes tow command etc. that the 7.3 didn't have.
3-Pick up a used 6.0 let the 6.7 get the bugs worked out and trade it(or sell it) then get the newer DSL.
Old Mar 10, 2010 | 03:29 PM
Oakman's Avatar
Oakman
I totally agree with what mwsF250 said. Good advice.
Old Mar 10, 2010 | 03:46 PM
Ace!'s Avatar
Ace!
I'd buy a 2011 truck. The reports of mileage on the new diesel is close to 25% better, sometimes more, than the 6.4L diesel.
Old Mar 10, 2010 | 04:35 PM
tex25025's Avatar
tex25025
I think v10s in the 250 and 350 are going to increase anyway given that your only going to be able to get v10s in the 450 and 550 chassis configurations from 2011 on(or atleast in the near future).
