Steering Column Bearing
Old 03-09-2010, 12:51 PM
cts1954's Avatar
cts1954
cts1954 is offline
I am preparing my steering column for the day that my cab is back on its frame. There is a rubber bearing in the upper end, also I see there is a bearing and sleave listed to replace this bearing. I am hoping I can source a bearing at my local bearing supplier, does anyone know what the number of this bearing is. The ideal size would be an ID of .750 and and OD of 1.5, I don' see anything like lis listed and I suspect that the sleave is to adapt the column to a smaller size. I am sure someone has replaced this bearing.
Thanks
Old 03-09-2010, 05:55 PM
AXracer's Avatar
AXracer
AXracer is offline
The steering column is very slow moving compared to most bearing mounted shafts, and has no appreciable side load. The bearing is there more to hold the shaft centered in the housing than anything else, so you don't need anything fancy or high precision, even a turned delrin or nylon block would do. (That's what the aftermarket manufacturers like Flaming River and Ididit use in their columns)
