Airbags Done!!
Old Mar 10, 2010 | 11:22 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by big poppa
I share Dan's point and concern, maybe those bolts need to be turned around to allow the room so those ends don't hit the leaf. Jeremy, nice job and pics and your really going to enjoy your trips now, in comfort.
Looks to me like the nuts are on the outside of the springs, Mike.
Old Mar 10, 2010 | 11:42 AM
cowboybootlegger's Avatar
cowboybootlegger
Mike, i installed a set of these bags on my buddy's F250, he had the overload spring also- and the carriage bolts don't hit the lower springs, they're tight, but they clear. Even with 90 psi in the bags, 2000 lbs in the bed, and 1000 lbs trailer tongue weight.
Old Mar 10, 2010 | 11:49 AM
cowboybootlegger
Jeremy, another option for routing the fill valves- to the lower license plate bolt holes. They're already the correct size for the valve, all you have to do is slightly enlarge the hole on the license plate itself, makes for a clean, easy to access install. That way you don't have to worry about them getting muddy, hit with rocks, ect.
Old Mar 10, 2010 | 12:33 PM
redfire42's Avatar
redfire42
Originally Posted by danskool
Nice job.. My next project for sure.. I have a question though. Although all my pictures of folks mounting the bags just as you did, It appears that the helper spring if used will cause interference of the bracket and the spring pack. Is this so? Will it "Clank" over the bumps? Especially when squatting a bit from a heavy camper.
Those bolts are not under the spring just to the outside, so no clanking.
Old Mar 10, 2010 | 12:36 PM
redfire42's Avatar
redfire42
I like that, I like it alot. Never thought of that. There kinda hidden but not. Thanks
Old Mar 10, 2010 | 12:43 PM
redfire42's Avatar
redfire42
Originally Posted by miller_feed
How do they ride loaded and unloaded?? How much air will you run in them loaded and unloaded?? Good job on the install.
Rick I didn't tow or hall anything yet but I tell ya the ride even empty is smoother. I am running about 12 pounds right now. It even handles better around turns and I don't have a rear sway bar. I only pull a TT at about 9200lbs gross so I only might run 25-30 psi. I am excited to feel the diference since before with out the bags on some roads you could feel it in your teeth.
Old Mar 10, 2010 | 12:58 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by mongo75
I'd like to add air springs, but I alread have 5th wheel brackets, welded to the gooseneck bracket, right above the springs LOL. I don't even know where I could put the bag brackets!
AirLift makes a different bracket if you have a fifth wheel hitch installed. It has a larger tab on it and you have the drill the holes yourself. Sounds like your situation is a little different still. Just in case though, I'll attach some photos.
My set up was a little different because my F250 does not have the overload spring. This meant my U-bolts had a lot of extra thread exposed so the lower air bag plate would rest on ends of the U-bolts instead of sitting right on top of the spring pack. I made up some spacer pieces out of 1/2" steel plate and since I was at it, I made some for the bottom of the clamp as well. I then went to the hardware store for grade 8 cap head bolts to clamp everything together.
My upper air bag bracket looks crooked but it's installed correctly. Per the instructions, the upper and lower brackets must be parallel to each other and be in line with the path of axle movement .
Old Mar 10, 2010 | 01:04 PM
redfire42's Avatar
redfire42
OK another question, if I were to get a compresser where would I mount it? Where does everyone have theres mounted at?
Old Mar 10, 2010 | 01:18 PM
Shake-N-Bake
I mounted mine under the cab near the B pillar. There was a inner rocker brace that was the right size. The air pump came with a plastic housing to protect the compressor. I made sure the cooling vent slits were pointing towards the rear of the truck. I located my gauge, switch and release valve under the dash over the transmission tunnel.
I will be ordering an F650 dash from RiffRaff pretty soon and I'll be relocating these items onto that piece. I'll lose my little cubby hole but that's ok because whatever is in there just flies out anyway when I stomp on the accelerator.
Old Mar 10, 2010 | 02:23 PM
Mike F250's Avatar
Mike F250
So, the compressor hooks the two bags together?
Old Mar 10, 2010 | 02:28 PM
BDalton's Avatar
BDalton
I put my compressor under the back seat to keep it our of the elements. It only takes about 30 seconds of run time to inflate the bags, and is very quiet.
big poppa's Avatar
big poppa
Thanks Rick and you too Caleb, maybe its time for me to get a pair of specks One question for you guys, does these bags also help out on unloaded ride quality??
Old Mar 10, 2010 | 02:40 PM
  #28
Shake-N-Bake
Depends on which compressor you get. There are various brands and each brand may have several compressor options. Here is a link to what I used.
Air Lift Company - Products - Load Controller II
I chose the single gauge model, which hooks the two airbags together.
You can choose the dual gauge model and control each bag separately, however that may not be too common. Most people who use the dual gauge model have airbags at all 4 corners so they air up the front separate from the rear.
Old Mar 10, 2010 | 03:19 PM
  #29
cowboybootlegger
Well, i wouldn't say it improved the ride of the 5 trucks i've installed them on enough to make it worth the cost just for unloaded ride improvement (not saying you were suggesting that, just illustrating) but there was a marked difference for the better, with about 5-10 psi in the bags, unloaded. If you have a toolbox with a couple hundred pounds of stuff in it, or some other form of cargo under 500 pounds, it makes more of a noticeable difference. Hope that's not too confusing...a
Old Mar 10, 2010 | 04:02 PM
  #30
big poppa's Avatar
big poppa
Nope, not confusing at all, thanks. I do haul my 7000 pound or better travel trailer around a couple times a year but not sure getting the bags would be justified for me but always subscribing.
