Truck Cab
Old Mar 8, 2010 | 06:08 PM
ptboi94's Avatar
ptboi94
Truck Cab
i was wondering if anyone had a cab for an 85 f-150. it needs to be a standard cab, 4x4, manual, and no a/c. the cab needs to be in very good condition. so no major damage to it or rust. there can be surface rust on it because i can have it sand blasted. the cab is going to be used for the restoration of my truck. i would like it to be very close to nebraska if possible.
Old Mar 8, 2010 | 06:09 PM
fatdan460's Avatar
fatdan460
any cab from 80-96 should work
Old Mar 8, 2010 | 06:18 PM
ptboi94's Avatar
ptboi94
i know that but will the fenders, cowl, and dash bolt right up without any major problems
Old Mar 8, 2010 | 06:24 PM
fatdan460's Avatar
fatdan460
they all should, as far as i know the only interchangeability issue is you have to use the right core support for what ever set of fenders you use which has nothing to do with what yer doing. and the doors are different on the inside where the dash meets the door panels so if you get a different model cab get it with doors if possible
Old Mar 8, 2010 | 06:38 PM
Fordzilla80's Avatar
Fordzilla80
The dash bolts up differently,at least between 80-86 and 87-91.Probably the same for 92-96.
