Radiator/Fan Shroud
I read an article in a street rod magazine many years ago about making your own fan shroud. They taped one together from cardboard. Once they got the fit right they took it off, sprayed paint on it (to seal the cardboard), and then srayed it with a mold release. Then they layed up the true shroud out of fiberglass mat over the cardboard form. This of course was from the days before electric fans, and 10's of thousands of dollars to build a street rod.
I have the same issue where my shroud is long gone. I don't have a cooling issue, so I am not overly excited about it, but I would like to put one on. On the DC site for the 300 I6, it says, coming soon. They are not that easy to come across in the bone yards, or else I would have one. I am sure I will find one sooner or later.
I have the same issue where my shroud is long gone. I don't have a cooling issue, so I am not overly excited about it, but I would like to put one on. On the DC site four the 300 I6, it says, coming soon. They are not that easy to come across in the bone yards, or else I would have one. I am sure I will find one sooner or later.
Is the paint color on your firewall a stock color? Could not help but notice it is very similar to mine, if it is stock do you know the color code and name?
The "DC" site I would assume is Dennis Carpenter...
Dennis Carpenter Ford Car, F-100 Pickup Truck, Tractor and Cushman Scooter Restoration Parts
Dak
Dak
D7TZ8146C .. Fan Shroud / Obsolete / No Ford Dealer or obsolete parts vendor has any.
Original applications: 1977/79 F100/350 300 I-6 with optional at additional cost: Xtra Cooling or factory installed Integral A/C.
This is the only fan shroud listed for 1973/79 F100/350's with a I-6. The 1973/74 240's didn't offer one.
The fan shroud does NOT bolt or attach in any way to the radiator! It bolts to the radiator (core) support.
I don't know of any fan shroud...car or truck...that attaches to the radiator...regardless of what year the vehicle is.
btw: If y'all are looking for fan shrouds for 1973/79 V8's, several are still available from Ford.
Dak
Dak
Color Chip Selection
I have looked at other sites too but have never found a sample of the color. I noticed your truck color is similar mine and was wandering if yours is a stock color and if it is, what color it is?
Thanks Burt, I am still trying to get an idea of the original color for my truck, the color code is V which I have been told is a "Medium Chestnut Metallic" but I do not find that color when I go to
1979 F100/350's: The COLOR code is V for Medium Chestnut Metallic
1973/79 Passenger Cars: The COLOR code is 5M for Medium Chestnut Metallic.
The Ford basic part number for Medium Chestnut Metallic (cars/trucks) is 5144.
The 3 ounce tube w/brush of touch up paint: AL81-5144-B / The 6 ounce spray can: AL81-5144-H.
Since your truck is a 1979 w/a 300 I-6 > >
1) Shroud only came with the 300 if it was ordered with xtra cooling or factory A/C, in either case prolly has a bigger (different) radiator.
2) Shroud bolts to the same support as the radiator.
3) Radiator is the complete unit and the core is only the actual cooling element in the radiator.
Who's the Dummy here. LOL
Thanks
As I told someone several days ago (could have been you, I don't recall): 1973/79 Passenger Cars also came in Medium Chestnut Metallic.
Thanks
