Nope. You said the fumes go to the breather. They aren't supposed to go that direction. The breather hose is the intake air for the PCV. The valve should have full manifold vacuum pulling on it, to evacuate the fumes. This cannot take place without a supply of clean filtered air, therefore the hose to the breather and extra filter element attached to the end.
The OP says the valve popped out when he capped off the breather hose. I'd say that means either A) the hose/pipe from the PCV valve to the carb or intake manifold is plugged up inside, or almost totally plugged, or B) the engine has major blowby issues. The PCV line can be solved fairly easy. Blowby not so easy.
actually he said the fumes make their way to the aircleaner not the breather. on some trucks the pcv valve connects to the aircleaner not the intake.
Air cleaner/breather are pretty much the same, in my book.
I haven't seen a PCV valve plumbed to the air cleaner in a factory setup, since the PCV valve needs a strong vacuum signal to overcome the check ball inside it, and actually do anything......
As for the original issue, a huge vacuum leak (or in this case multiple vacuum leaks) will not only increase emmissions, but reduce the effectiveness of the PCV system. These vacuum leaks reduce the vacuum available to the PCV valve, which in turn reduces it's ability to properly function.
It sure does, thank you, I found a full manifold vacuum hose todaythat was disconnected, creating a leak. I also have a leaking intake manifold gasket. I found it today with starting fluid. I will replace the gaskets tomorrow.
I will keep you posted, thank you,
Nick
Yes, a vac leak would deffinantly cause those symptoms, please do keep us informed.
And as for the PCV being plumed to the air cleaner, Mopar loved doing that. If you ever work on a dodge, where a corner of the air cleaner is soaked in oil, its probably PCV related.
Mopar, that would explain it. I only know 1 person that owns a mopar, and it's usually broke down in his driveway. You guessed it, he's a "mechanic"........
Okay, I went in for a third test. The tech opened the hood and said it failed without even hooking it up (pre test really, so did not go against me). Some of the vacuum lines were hooked up wrong (I replaced some yesterday, but hooked them up like I had removed them). I also replaced the intake gaskets. Tonight, I re did some vacuum lines and replaced one of the discharge hoses from one of the two air pumps. I go back tomorrow.....
A later fuel injected truck is looking better.....slap me into reality and remind me why I love this truck!
After reading this entire thread I am sure glad I live where I do. Never has been any emissions testing here and won't be in my life time. I doubt Nappa even stocks pcv's for any thing I drive. We de-smog em. re-tune em and let em breath the way Old Henry intended. Here if it don't burn and leak oil it Prolly don't run.
Thank you guys, I am pretty excited. I only have the brake and light inspection, and then it will finally be registered! California is a trip when it comes to anything environmental. There is not much common sense when it comes to our leaders!
I know this thread should be done, but I wanted to just give a little update. I was messing with my truck yesterday and felt air coming out of the back of one of the smog pumps. I do not know all the techincal terms, but it was coming where it should not. I checked a little deeper and found malfunctioning check valves. The exhaust was overcoming the air being pumped in and air did not make it into the exhaust. I checked and found that will cause high HC's (my problem). I am going to fix them, if for nothing else, so they are working properly. I would love to test it again, BUT not going to since it will cost me money for something I do not need. Hope this might help someone. 2 smog shops and a lot of questions later and I found it.
