Rough Shifting on 06 PSD
Old Mar 8, 2010 | 10:34 AM
JCark's Avatar
JCark
I just bought an 06 PSD. It only has 27k miles on it. I have noticed that it shifts rough compared to my 99 5.4L. Im guessing that its because of all the torque the 6.0L makes, but every once and a while when shifting into 3rd gear the rpms jump a bit, only about 100-200 rpms, but its enough for you to notice, and it does not do that all the time. Should I bring the truck back to the dealer?
Old Mar 9, 2010 | 02:46 AM
JCark's Avatar
JCark
can some one tell me if this is normal or not? Please help, thanks.
Old Mar 9, 2010 | 08:03 AM
Zmann's Avatar
Zmann
the recomended flush interval is pretty early for these and the tranys are kinda finiky about their fluid SP shutter proof ,, you may want to start with a real hot flush?and filter (frame mounted) the valve bodies so to speak are all electronic and computer operated ,, , it might not hurt / or help but you can unplug the batteries for a bit then it will put the system bac into a learn mode and may change the feel
