Front ABS sensor
Old Mar 7, 2010 | 07:31 PM
2001X's Avatar
2001X
Front ABS sensor
Today my ABS light was on when I started the EX. When I got out I found that I had a thick wire in the drivers side wheelwell that was broken in half. It goes from the wheel hub to sort of behind the fender where it has a connection. I tried to splice it back togather but that did not work. So how hard is this to replace? Looks like the wheel will have to come off but how about the hub? Also whats a good source for the part. Thanks
By the way its an '01 4wd.
Old Mar 7, 2010 | 09:12 PM
JEV's Avatar
JEV
If you can find a sensor, it's an easy swap. There is a single bolt that holds the sensor in place on the bearing assembly. The other end is a simple electrical plug.
JEV
