How bad is This???
Old Mar 7, 2010 | 03:25 PM
Timon5435's Avatar
Timon5435
How bad is This???
Draining Fuel Seperator and the threads broke off. The plug barely fits in there now and is loose. How do you rethread(if possible) or do I need to get to the dealership and have the entire thing replace?
Thanks in advance...
Old Mar 7, 2010 | 04:21 PM
cheezit's Avatar
cheezit
you shold replace the wif manifold. it can be bought without the pump.
Old Mar 7, 2010 | 05:21 PM
Timon5435's Avatar
Timon5435
Great...I have researched and have a couple of questions...
1. Is the manifold something that is stocked at the dealership?
2. When I pull the fuel lines off the manifold will I need to plug the line that is coming in from the fuel tank, and also will fuel drain out of the other lines coming back from the engine?
3. Is it safe to drive if the plug falls out? And what will happen if the plug falls out while I'm driving, or will I even know that it is out until I stop?
Thanks for getting back to me....This is my wife's EX so I need to plan on borrowing something tomorrow for her if the part takes longer.
Old Mar 7, 2010 | 05:25 PM
06silvercrew's Avatar
06silvercrew
Most dealers that do diesel work should have it on the shelf.
You dont need to plug the lines IF you remove them, but yes they will drain out and make a mess pretty much no matter what you do so have a big drain pan nearby and dont have your sunday clothes on. Take the fuel cap off before you start just to be sure no pressure in tank.
If the plug falls out it wont run, and it will **** fuel EVERYWHERE FAST. If its even questionable I would not drive it until you get it fixed.
Old Mar 7, 2010 | 05:26 PM
cheezit's Avatar
cheezit
we stock them. but dealer stock changes from shop to shop.
the fuel pump manifold has 4 line on it 2 supply and 2 return that must be removed. you will need a tool for that but there are cheep at autozone or the like $10 or so.
you will have fuel in the lines that will drain not a big deal.
if you fail to have the drin valve seal correctly you can suck air in to the fuel system not a good thing.
if it falls out you will dump fuel all over the place and suck lots of air. could possible die going down the road as a result.
also leaking can casue low fuel pressure and volume
Old Mar 7, 2010 | 07:05 PM
Timon5435's Avatar
Timon5435
Alright...First Thanks for the response.
Just got back from Auto Zone...picked up the removal tools for the fuel line (not sure how they work yet by looking at them, but I think I can probably figure it out.
Anything else I should be aware of during the replacement.
Do I just put all the hoses back into the manifold and reconnect the electrical and crank her up? Any priming of the fuel lines or anything else you would do?
Thanks...I'll keep you posted on how the change goes with pictures and a step by step so that I can help out the next guy who does this.
Old Mar 7, 2010 | 07:06 PM
cheezit's Avatar
cheezit
cycle the key 5 to 6 times once every 30 sec. that should prime the system
Old Mar 7, 2010 | 07:32 PM
solaratomic's Avatar
solaratomic
The tool clips onto the lines on the manifold side and slides into the snap fitting. It releases the clips inside the fittings. Spray the inside of the connections w/ WD-40 or equivalent...it helps... a lot. Clip on the tool, push line towards manifold and at the same time push the tool into the fitting. Pull it all out as a unit. Ford has been using these fittings for years and they suck. It may take you a little while to get the first one, but by the time you get done with all of them you'll be a pro.
Old Mar 7, 2010 | 09:38 PM
Timon5435's Avatar
Timon5435
Great...One more thing...
through reading it seems like they have deleted the heater, and the new manifold does not have this heater and some people have to install a new wiring harness??? part number 6c3z-9f759-a what does that involve and is it something that can be done at home?
Old Mar 7, 2010 | 09:58 PM
cheezit's Avatar
cheezit
ya that is a short jumper harness. its 3 connectors. the harness is like a 1' long. I forgot to mention that. all the harness has that is different is they deleted the fuel heater connector.
