what do you guys think?
Old Jan 22, 2003 | 12:22 PM
RUFUS79's Avatar
RUFUS79
Question what do you guys think?
hey guys this web site is very helpful I've learned alot from here anywhoot I was wondering how hard is it to change out an automatic for a 4speed manual. I am thinking about buying an 84 f250 with a 460 and the only thing is that it has an auto and I don't like them a one bit. My step dad has an 83 with a 460 and a 4speed that I could get from him. how hard would it be and what would I need
Old Jan 22, 2003 | 06:56 PM
steve83's Avatar
steve83
Since both have the 460, it should be pretty straightforward. You'll have to swap your pedal bracket for one with a clutch pedal (and the switch), put in a floor panel on the hump that has the cutout for the shifter, get a steering column that DOESN'T have a shifter, and maybe move the crossmember and cut the driveshafts for length. I recently helped a the guy who runs BroncoData swap an M5OD into his '93 Bronco for the old E4OD that was trashed, and he can give you some advice, too.
Old Jan 22, 2003 | 09:16 PM
RUFUS79's Avatar
RUFUS79
thanks steve83! also could I just use the driveshafts that are on the other truck?
