I have a manual cab and looking at getting a truck that has automatic cab. Is it possible to swap the clutch linkage i have into an automatic cab? Is there anything elese you have to do?
I pulled my automatic assembly yesterday to replace it with a manual one, and I ended up just swapping the clutch pedal and spring on the donor for the pin on the original, which turned out to be in better shape. They interchanged perfectly...slide one out, slide the other in.
Since I had two, I had the option of which brake pedal to use, and I personally prefer the automatic brake pedal to the small manual one. There's still enough clearance to keep from stepping on one when you are aiming for the other.
