why can't i find a leveling kit for my 99 superduty? they ask me when it was built, i tell them late 98. but come on its a 99 so shouldn't 99-04 kits be the same for leaf spring applications?
A 315/75R16 tire is 34.5" tall. You can get away with a 2"-2.5" leveling kit if you don't do any off-roading. If you do any serious off-roading, then you may want to go with a 3"-4.5" lift kit. Also, depending on the condition of your front and rear leaf springs, you may want to replace them as well. I see that you currently have Pro Comp shocks. You may have to replace them with the 2"-2.5" leveling kit and definitely with a 3"-4.5" lift kit.
I'm a big fan of Icon lift kits. As I see it, you have several options...
Option #1 - Install an Icon 2" leveling kit only at a cost of $230.00. This will remove any rake on the truck. It's the least expensive option but does limit the trucks ability to off-road (minimal articulation).
Option #2 - Install an Icon 3" "Hanger" lift kit. The kit without rear blocks costs $950.00. The kit with rear blocks costs $1,133.00. Both kits include new front & rear shocks. This is definitely a more expensive option. Also, it's in the grey area in terms of front end alignment issues. These lift kits do not include a drop track bar bracket, drop pitman arm, and sway bar end links. You'll get better off-road capabilities with this option but nothing significant. I don't really recommend this option.
Option #3 - Install an Icon 4.5" "Hanger" lift kit. This kit costs $1,569.00. This kit includes hangers, drop track bar bracket, drop pitman arm, and sway bar end links, front & rear shocks, and rear blocks. The only thing that remains shock are the front & rear leaf springs. This kit will provide much better off-roading capabilities.
Option #4 - Install a 4" "Spring" lift kit. This kit costs $1,743.00 and is only $174.00 more, which IMO is a much better value than Option #3. Like Option #3, this kit includes drop track bar bracket, drop pitman arm, and sway bar end links, front & rear shocks, and rear blocks. If wanted either now or in the future, you can add the Icon 5" rear leaf springs for $675.00 which would result in a 100% suspension upgrade.
thanks furian, i don't really do any off roading. i do go out in the middle of the desert to go shooting but i do it with the stock suspension. i think i'll just do the 2 21/2 incher.
Understood... post up your thoughts of the new leveling kit.
