Problems re-starting a cold engine
Old Jan 22, 2003 | 11:39 AM
Nineteen19's Avatar
Nineteen19
Exclamation Problems re-starting a cold engine
Hi Everyone,
I have a 1991 Ford Explorer Eddie Bauer Edition; 139,000 miles on it. When I start the engine, the first time it will fire right up. However, if for some reason, I need to turn it off before it warms up, it will only turn over the next time I try to start it. I have discovered if I hold down the gas pedal, it will start up again. This morning I had to hold it down for awhile before it would start running again! Am i missing something very basic? Is this common?
If anyone has any ideas, it'd be great to hear them!
Thanks,
Jimmy Lee
Old Jan 23, 2003 | 06:41 AM
hoppy's Avatar
hoppy
Run the codes on it. Sounds like it may be the throttle position sensor or the ignition control module.
Run the codes and see if it gives you any ideas.
hoppy
lee_2000_eb_owner
Jan 12, 2009 10:45 AM
Lee Lichterman
Mar 15, 2006 11:35 AM
DarkWolf40
45
Jul 20, 2005 12:23 AM
Jimmy Dean
Mar 21, 2004 10:11 AM
