82 Bronco
Old Mar 6, 2010 | 08:37 AM
redhawk41's Avatar
redhawk41
82 Bronco
I have an 82 Bronco and want more power. My solution is to put 4.11 gears into it. My question is are F250 or F350 gears interchangeable in the front and rear axles?
Old Mar 6, 2010 | 08:38 AM
redhawk41's Avatar
redhawk41
Also are the hubs interchangeable? Can i get 8 lug wheels to fit the bronco front end?
Old Mar 6, 2010 | 02:01 PM
Franklin2's Avatar
Franklin2
No on both counts(the front axle is a maybe). Look at the rearend in the Bronco. If it's smooth with no bolts showing, then you have a 9 inch rearend. If you look and it has a cover with bolts going around the outside, then you have a 8.8 rearend. You can get 4.11's for either style from summitracing or somebody like that.
Your Bronco has a dana 44 ttb. A lot of the f250's had a dana 44hd ttb in the front. There is a chance the gear section may interchange, but wait for someone who knows to confirm that. If it won't, you can buy 4.11's for the front just like the back.
You probably can also buy 16" rims with 5 lugs if you want to run those type tires.
Old Mar 8, 2010 | 09:30 AM
oldbrokecowboy's Avatar
oldbrokecowboy
Bronco questions
Check out the bronco forum. Also try the search feature. If I remember correctly there is a thread about puting che?y outer knuckles on your housing and getting 8 lug, etc. I did the ford 8 lug swap, (3/4 ton running gear, 50 ttb and lt duty 60) it worked but I'm not happy with it.My fault/ workmanship, not the concept. Best result though was the brake improvement. Should have had this size brakes from the factory. Have also done the 1 ton brake up grade to my 80 bronco, not as impressive as the other. OBCB
mattgixxer1
New Member Introductions
Nov 14, 2014 02:26 PM
BroncoMonster82
1978 - 1996 Big Bronco
Jul 2, 2012 08:00 PM
rdnjr
Oct 21, 2003 04:47 PM
grizzlyadams73
Sep 13, 2003 11:55 PM
msautry
Nov 18, 2002 07:43 PM
