Injector Pump
Old Mar 6, 2010 | 06:57 AM
bigblu78's Avatar
bigblu78
Injector Pump
Has anyone ever rebuilt and injection pump themself here? I have an old 88 250 farm truck that needs the IP rebuilt and the trucks not worth the $450 for a new one. I was thinking about doing it myself but I like to be a little better informed before I tackle these things. I've rebuilt motors, trannys, axles and about everything else on trucks so this can't be too awful difficult. Thanks in advance!!
Troy
Old Mar 6, 2010 | 08:33 AM
starmilt's Avatar
starmilt
I never say something can't be done, but I don't know how you will be able to do it without a pump bench.
Old Mar 6, 2010 | 01:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The rebuild would not be hard, but without the test bench you would have no way to set it up.
If you buy the IP rebuild kit, do the rebuild, then take it to a fuel injection shop for calibration, you will have more in it than the rebuilt price.
Old Mar 6, 2010 | 02:23 PM
rupejosh's Avatar
rupejosh
what is it doing that makes you think it needs rebuilt?
Old Mar 6, 2010 | 04:17 PM
drewdole's Avatar
drewdole
what about the ones at pensacola diesel for 300 bucks. now im no pro on this , i do wonder how long these pumps last, and i ve seen they should be tuned in or something. i guess what im wondering is if u buy one for 300 bucks and bolt it up r u good 2 go, or does it need to be tuned in , what ever that means. i do believe these pumps have been replaced on both of my trucks.
Old Mar 6, 2010 | 05:08 PM
Dave Sponaugle
A few people have had problems with Pensecola Diesel IP's, but not nearly as many that have had trouble with Diesel Care's IP's.
Like most things, you get what you pay for.
Last time I looked Midwest Injection was getting around 500 for a rebuilt IP and has a much better reputation.
Old Mar 6, 2010 | 06:43 PM
kenpobuck's Avatar
kenpobuck
Has anyone ever used a pump from silverstate ford? Do they sell rebuilt or new pumps? They list a pump for $446.00 after core charge.
Old Mar 6, 2010 | 08:15 PM
typefour's Avatar
typefour
Do not buy any reman pumps thru a ford dealer, 2 mechanics that i know have had only 2 in 10 work right. Probably rebuilt in cuba.
Old Mar 7, 2010 | 12:19 PM
kenpobuck's Avatar
kenpobuck
That is good to know. I figured they may be better rebuilds.
Old Mar 7, 2010 | 06:36 PM
bigblu78's Avatar
bigblu78
I am not getting any fuel to the injectors. I am getting fuel to the pump but nothing past that. I have changed the fuel shut off solinoid and that didn't fix it. I have power to everything. The truck has been sitting for a while and the last time I drove it I had trouble getting it to refire when it was warm (ie. after running it and shutting it off) Just assume its gone bad.
Old Mar 7, 2010 | 07:49 PM
rupejosh's Avatar
rupejosh
it may be as simple as a weak lift pump.have you pressed the schraeder valve to see how much fuel comes out?how much fuel is in the tank?is the fuel filter full and does it stay full?
Old Mar 7, 2010 | 08:55 PM
Dave Sponaugle
Remove the schrader valve core on the filter header.
Install a pressure gauge, 3 to 7 PSI while cranking the engine over.
Now remove the gauge and route the fuel into a suitable catch can, minimum of 1/3 pint in 10 seconds cranking the engine over.
Old Mar 8, 2010 | 09:05 PM
bigblu78's Avatar
bigblu78
I will give that a shot.... Like I said.. this thing just sits most of the time so it has become one of those "I might work on that next weekend" projects. Hate to say that but when you've got a full schedule it happens sometimes.
