Why can't I?
Old Mar 5, 2010 | 05:09 PM
89bronc's Avatar
89bronc
Why can't I?
I have been researching the shackle flip threads and a thought came to mind! Why can't I just build some new mounts(front and rear) and drop my shackles down.I do not plan on going crazy-just 4-6 inches.Let me also add I am a ASME qualified welder/fabricater by trade.I can build these for about $5 (ya- I get a huge cost break at work on anything steel, carbon or stainless) My truck is a '75 F 250 crew highboy with dana 60 front and rear.Any pros or cons you can think of???
Old Mar 5, 2010 | 06:09 PM
montana_highboy's Avatar
montana_highboy
I say go for it, take pics along the way and post a build thread when you're done.
Old Mar 5, 2010 | 06:33 PM
hp246's Avatar
hp246
Actually thats how DJM's kit works. you remove the factory mounts and replace with the DJM Mounts.
Old Mar 5, 2010 | 07:25 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
It will work. However, vehicles have what's known as a "roll-axis". Simply put.......your truck will have more body lean with stock springs on lowered mounts, vs lift springs on stock mounts.
Old Mar 5, 2010 | 07:30 PM
460/5's Avatar
460/5
Zombie Survivalist
^^^ what hillbilly said, but it can be fixed with a set of torsion bars.
Old Mar 5, 2010 | 08:11 PM
starmilt's Avatar
starmilt
Lets hear more about them torsion bars.
Old Mar 5, 2010 | 08:15 PM
460/5's Avatar
460/5
Zombie Survivalist
torsion bars, also known as anti-roll and anti-sway bars link one side of the axle to the other to keep the chassis from tippin so much in turns. however, they are flexible and will allow independent movement, but they do limit "flex", which makes them undesirable to a lot of off-roaders. which is why warn makes a set up that can be locked for highway use, and unlocked to allow full flex on the trails.
Old Mar 5, 2010 | 08:23 PM
89bronc's Avatar
89bronc
Another question- I know I will need a drop pitman arm,anyone know where I can get one for a '75. Also I have the closed knuckle 60 up front,I still have the power assist ram upfront for now-another project for the future is the steering conversion, but one thing at a time!
Old Mar 5, 2010 | 08:40 PM
HillbillyDeluxe81
No such thing as a drop pitman arm for a "highboy". You'll need to raise the steering arm.
Old Mar 5, 2010 | 08:47 PM
89bronc's Avatar
89bronc
that explains why I cant find one! lol Everything I find cuts off at the "77 year. So as I understand-just need a block and some longer bolts correct? Thanks for all the help
Old Mar 5, 2010 | 08:52 PM
starmilt's Avatar
starmilt
Always called them sway bars, I thought you were talking about torsion bars like you would find under a chevy or dodge.
Old Mar 5, 2010 | 09:03 PM
460/5's Avatar
460/5
Zombie Survivalist
lol. different parts of the country i guess... or maybe im just weird...
