auto hubs
Old Mar 5, 2010 | 01:23 PM
kupaa's Avatar
kupaa
auto hubs
I have auto hubs but can manually turn them off,if i turn them off will it be better for the bearings,frontend and will i get better mailage?
Old Mar 5, 2010 | 01:25 PM
crazymut's Avatar
crazymut
I would say no. If 4x4 is not selected then your hub is off. The **** is there incase your auto hub does not work.
Old Mar 5, 2010 | 02:12 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You can either turn the hubs to AUTO or LOCK. If you choose AUTO then your hubs will unlock once you turn the switch in the cab to 2wd. If you choose lock, then your axles will turn all the time, even when in 2wd.
