Help with axle selection!
Old Apr 23, 2010 | 11:54 PM
xjpilot's Avatar
xjpilot
yeah, i know to take what the "big boys" say about the ttb with a grain of salt. I know that if it stood up to what my grandfather put it through for 15 years, it will stand up to what I will put it through.
Old Apr 24, 2010 | 10:43 PM
xjpilot's Avatar
xjpilot
so I am going to check out this ttb tomorrow hopefully, and I thought of another question for you guys. My big concern is knowing what types of things to check for, like wheel bearings, hubs, etc, and how to check them. I've never really needed to check these things before, so I've just got no clue. also, I'm pretty sure that the bolt pattern will be 5x4.5, but can someone reassure me that's right? Now lastly, how hard will it be for me to convert this thing to manual hubs, assuming that by '95 or whatever he said it was that they had already switched to the automatic ones?
thanks for the help guys, its always appreciated!
Old Apr 24, 2010 | 11:02 PM
Franklin2's Avatar
Franklin2
The bolt pattern is 5 x 5 1/2. You have all the stuff from your old ttb, so you should have enough parts to get the newer one going.
Bearings are cheap enough as well as seals. The only thing I would check is the slip joint on the passenger side. See if it wiggles side to side. If it does, it's worn and that will require a new passenger side axle. But you still have your axle in your ttb is it's any good.
Old Apr 24, 2010 | 11:31 PM
xjpilot's Avatar
xjpilot
and I think 5x5.5 is what I meant (same as my '82?). And unfortunatly my old ttb is one giant hunk of rust, so I don't think I'm getting much off of it. Internals may be good, but thats probably after they get cut out
Old Apr 25, 2010 | 09:15 PM
xjpilot's Avatar
xjpilot
so i picked up this ttb today, and its just about clean enough to eat off of. all the stickers are still there, perfect shape, just a tiny bit of surface rust on the rotors. It does have auto hubs though, which sucks. but I guess an extra $30 for warn premiums is worth it.
One question though, there is wiring harness comming out of the back of each rotor; is this for the auto hubs or ABS? If its ABS, how easy is it to ditch?
Old Apr 25, 2010 | 09:29 PM
82F100SWB's Avatar
82F100SWB
That wiring harness is for ABS, only the Broncos ran it, and as far as you're concerned, you can just cut the wires off.
Old Apr 25, 2010 | 09:48 PM
xjpilot's Avatar
xjpilot
sounds good to me
IDIDieselJohn
Jun 18, 2014 10:51 PM
Radster
24
Jun 12, 2013 07:41 AM
justforkicks
Jul 5, 2009 07:46 PM
69crewcab
Jul 13, 2004 08:37 PM
