Distributor Rotor - Engine Bucking/Surging
Old Mar 4, 2010 | 12:16 AM
THE BLUE HEAP's Avatar
THE BLUE HEAP
Hi all,
I just found this TSB on alldata, can anyone tell me where exactly this silicone grease is applied to at the distributer?
Thanks allot
Article No. 85-21-8
ENGINE MISS - DISTRIBUTOR WITH BLADE ROTOR - SILICONE GREASE
ENGINE SURGE - DISTRIBUTOR WITH BLADE ROTOR - SILICONE GREASE
RADIO NOISE - DISTRIBUTOR WITH BLADE ROTOR - SILICONE GREASE
FORD 1986 ESCORT, EXP, TEMPO, MUSTANG, THUNDERBIRD, TAURUS, LTD, CROWN VICTORIA
LINCOLN-MERCURY 1986 LYNX, TOPAZ, CAPRI, COUGAR, SABLE, MARQUIS, CONTINENTAL, MARK VII, LINCOLN
LIGHT TRUCK 1986 E/F SERIES, BRONCO, RANGER, BRONCO II, AEROSTAR
<TABLE cellSpacing=2 cellPadding=1><TBODY><TR vAlign=top><TD>CALIBRATION:</TD><TD>All with EEC IV
</TD></TR></TBODY></TABLE>
1986 vehicles are equipped with a new "blade" design distributor rotor. This design replaces the multi-point rotor used in recent model years. This new rotor requires the use of silicone grease on the blade. Electrical interference can result from a blade rotor that does not have silicone grease. The electrical interference affects the distributor stator assembly and can cause engine "missing", "bucking", or "surging". These drive concerns are usually intermittent and tend to occur during crank and heavy or wide-open throttle.
It is important to remember not to remove the silicone grease for radio noise concerns, on 1986 vehicles with EEC IV; removing the grease can cause driveability concerns. A future TSB article will address the radio noise issue.
<TABLE cellSpacing=2 cellPadding=1><TBODY><TR vAlign=top><TD>OTHER APPLICABLE ARTICLES:</TD><TD>None</TD></TR></TBODY></TABLE>
Old Mar 4, 2010 | 07:21 AM
subford's Avatar
subford
Just clean any grease out of the cap and replace the rotor with the new improved one,
Part number: E6TZ-12200-F
Fits: 85-93 w/EFI
Old Mar 4, 2010 | 07:34 AM
THE BLUE HEAP
Thanks,
I did change the rotor to the new one also the cap
vloney
6.7L Power Stroke Diesel
Nov 2, 2013 09:56 PM
matty169
Oct 11, 2010 12:47 PM
ccerniglia
Oil & Lubrication
18
Oct 17, 2008 10:51 PM
96_4wdr
Aerostar
Mar 5, 2008 02:09 AM
