Will this work?
Old Mar 4, 2010 | 12:01 AM
truckerboy's Avatar
truckerboy
Will this work?
Hey, i am gunna thank all yall ahead of time.
ok, so I have an 81 F100, 300 I6 carb. and a manual transmission, atually a three on the tree. I have a motorcraft (i think, its not the origional, but is a direct advance auto replacement) and the electric assist choke. I am wanting to know if the truck would run ok without the hot air system under the carb.
I am rebuilding the motor and in the process discovered that the manifold is cracked rather badly, and is severely rusted. I want to upgrade the intake to use a 550 cfm holley and headman headers, but the headers that i have dont have the hot air attachment. If this works, will it pass NC inspection without the hot air system?
Old Mar 4, 2010 | 12:22 AM
Franklin2's Avatar
Franklin2
If you look at clifford performance website, you can find they sell a block that coolant flows through to help heat the bottom of the manifold and carb. If you keep the stock aircleaner with the hot air hose going to the exhaust manifold, that will help also.
Passing emissions is not the problem. If you run it with no heat in the manifold or under the carb, it will be very cold natured and not run very well till it's warmed up. If you try to run it in the winter on a cold damp day, it will really give you a fit and keep stalling till you finally get some heat to the carb.
The problem is gas engines will not burn liquid fuel. It has to be atomized into a mist. The carb does this normally, but when the mist hits the cold manifold, it turns back into a liquid. The manifold is heated by the exhaust to create a hot spot, and this keeps the fuel atomized so it runs well when it's cold. That's one of the big advantages of fuel injection, there is no fuel in the intake manifold.
Old Mar 4, 2010 | 12:35 AM
truckerboy's Avatar
truckerboy
when i got the truck, the air cleaner wasnt included. Is this the same as one from the small block v8's or is it strait six specific?
ok, is there any way to heat the carb without the hot air valve? (is this an egr valve?)
is there any kits out there to use efi from a small block chevy on this motor? I have a chevy that im workin on the has the fullmotor fuel system on it (pre vortec 350), about all thats good on that damn motor. Guess i can make it work
thanks for the lesson on what it does.
also is that big pump thing that is connected to the hot air system necessary? (or is it just robing power from the motor?)
Old Mar 4, 2010 | 12:42 AM
Franklin2's Avatar
Franklin2
I am assuming the pump thing is the smog pump? If so, you can take it off, it's not part of the hot air system to the carb. If you have inspections though, you had better leave it on there.
Old Mar 4, 2010 | 12:45 AM
truckerboy's Avatar
truckerboy
ok, thanks. It is a smog pump, i am pretty sure of that.
Is there any special proceedure for replacing it with a new one?
Old Mar 4, 2010 | 12:48 AM
Franklin2's Avatar
Franklin2
No, should bolt right on.
Old Mar 4, 2010 | 12:50 AM
truckerboy's Avatar
truckerboy
ok. thanks.
What does the smog pump do?
Old Mar 4, 2010 | 12:57 AM
Franklin2's Avatar
Franklin2
Pumps air into the exhaust for emissions reasons.
Old Mar 4, 2010 | 12:59 AM
truckerboy's Avatar
truckerboy
so it basically dilutes the poluted air going into the cat. converter?
Old Mar 4, 2010 | 01:04 AM
Franklin2's Avatar
Franklin2
Sort of. It's more complicated than that, but that's basically the jist of it.
Old Mar 4, 2010 | 01:13 AM
truckerboy's Avatar
truckerboy
ok, that makes since. thanks
Do you know if the efi from a chevy 350 can be adapted to the 300?
Old Mar 4, 2010 | 11:46 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
No, it can't be adapted for it. For one the chevy 350 is 8 cylinders, and the 300 is only six.
If you want to go EFI, get a Ford system from a 300-I6 out of a 1988/1996 truck.
Ask your state about laws governing this as well, because in california, you have to jump through the burecratic hoops...
Old Mar 4, 2010 | 12:37 PM
Littlejon's Avatar
Littlejon
You need to bring it down my way and let the boys at my local shop inspect it. They do a REAL "thorough" job on older vehicles!
Old Mar 4, 2010 | 12:47 PM
86bigred's Avatar
86bigred
it can be adapted.here's a link to gm tbi kits to retrofit on any engine.
Howell Engine Developments Inc. - Home
here it is installed on a (i know it's not ford) slant 6.
http://www.rowand.net/shop/tech/SlantSixTBISwap.htm
Old Mar 4, 2010 | 02:12 PM
Franklin2's Avatar
Franklin2
Throttle body fuel injection is a step up from a carb, but you still have fuel in the intake, so you still have the same fuel atomization problems, so you still need to heat the manifold for it run right. That 350 chevy has exhaust running up through the intake to warm it up just like your six. The ford system for the six is multi-point, a much better system with a dry intake manifold.
