I'm looking for a drivers side door for my 67 F100.
Welcome to FTE
Do you need the bare door shell itself, internal parts for the door or a complete door?
1967 doors are one year only. 1967's do not have door lock *****.
1967 only: door shells, window regulators, door lock remote controls, door latches and linkage, inside window crank and door handles, armrests, vent frames, vent handles.
None of these parts are the same as 1968/72.
You can bolt a 1968/72 door onto a 1967, but it won't match the other side.
I need the complet door the truck I have has 2 diffrent doors on it the passgener door is a 67 and the drivers door is a 68 i would like to put a 67 on the drivers side befor i do a paint job.
I would recommend changing the door to a later 68 to 71 they are a lot easier to find. It also helps to post where you are from. Some one may have a spare laying around.
Ok im In south west GA I just found out both my door may be 67's but the the drivers side has the door handle in an armrest it has a push lock where the passageners side has no arm rest and has a pull door handle and you also lock the door with the door handle. I have no problem getting a newer modle door but I want them to match.
