More than likely the 4wd life will not work on a 2wd. The 2wd has independant front suspention and the 4wd has a solid front axle. Check into the Ranger.
No the 4x4 lift will not work because the IFS front axle in the BII 4x4 is differnt then the one in the 2 wheel drive model's. But im not sure about the Ranger lift they look to have the same Front IFS and rear axle as the BII but Im not sure,
