2002 ford superduty 7.3 no power to driverside valve cover gasket
I have a 2002 ford f 250 powerstroke. it will hardly start and runs poor i pulled the plug out of the valve cover gasket truck died so i started it back up pulled the other side truck stayed running i tested the wires and the glow plug wires will get power and the injector ones nothing. i checked all fuses under das no blown fuses. any answers? thanks
Sounds like your UVCH is loose on that side. The wires in the connector will not show power. They are this configuration. G-G-I-I-P-I-I-G-G.
The G is for Glow Plug
The I is for Injector Ground
The P is for Injector Power
Pull the valve cover and I bet you find the UVCH is loose.
Here is a web page to read about it too. » TB 103: 1994-03 Ford 7.3L IDM Replacement & Diagnostics
disturbinglee
09-04-2019 08:39 AM
rollinblackcloud
05-01-2014 09:10 AM
